Those were photos of the petrol before i took it out.
I still have the same problem. i'm completely done (i think) apart from whatever i should wire onto the clips in pic1
The yellow one is the oil pressure switch which both engines had so that was easy. The two clips next to the large coolant hose is labeled as the thermostat connections in my diesel haynes, but i can't figure out which wires i should connect to it now. So many options.
Only otherthing is the alternator. I would have liked to have kept the cabriolets alternator but it didnt fit in the engine bay anymore so the diesels alternator is back on. But wiring is different again.
Blue to blue would make sense. And i'm guessing both reds on the harness connect to the big red wire. Could be wrong.
Apart from this i have diesel in the tank and primed it through using the lift pump. Everythings ready to go i thought. But when i turn the key after giving the glow plugs some time to warm up i only get the starter and the engine doesnt start. I have 12v at the stop solinoid and 12v at the GP's so i don't know why it wont go. Should the GP's be warm to touch after being on for 30 seconds? Or does this sound like a fuel problem again?
