Results 1 to 10 of 10
Thread: Dash wiring for RWC.
    Jan 2010
    Baulkham Hills
    Hey y'all,
    after salvaging the blue beast in march, i have ticked a lot off my to do list...
    body-
    Gti arches *
    crosshairs*
    upswept exhaust*
    mk2 style grille*
    straightened chrome bumpers*
    replacement front drivers quarter*
    hard cutt and polish*
    repaint all exterior black trimming*
    white retro 15" rims with low profilers*
    engine/running gear-
    replaced screwted driveshaft & CV*
    machined front rotars*
    referb rear drums*
    replace timing belt*
    replace plugs and leads*
    replace all hosing*
    rewired ignition and coil*
    full oil change*
    empty/clean fuel tank*
    tighten brake clutch and throttle cables*
    And left to do is wiring the dashboard...
    the previous owner had a shot at replacing the LS dash with a newer GLS dash... hmm surely the are no different..
    anyways... basically nothing has ACTUALLY been reconnected... the dash was just re mounted and made to look pretty
    SOoooooosooooosooooo... all i need to get roadworthy is headlights, indicators and demisters working prime.. is it hard to do?? are there DIY's around?? or should i get an auto electrician to charge me a crap load and do it properly??
    oh and i did all of the above listed (includiing the cost of the car) for under 1500 bucks gotta be happy with connections!!!! and forums
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
    Jan 2009
    Hobart, TAS
    Quote Originally Posted by JoshFair View Post
    Hey y'all,
    body-
    Gti arches *
    crosshairs*
    upswept exhaust*
    mk2 style grille*
    referb rear drums*
    replace all hosing*
    full oil change*
    if you are keen on doing much work on the engine or electrics yourself,
    maybe you should consider getting a workshop manual... would be very helpful for things like this with diagrams etc.
    as for headlights, indicators, etc.. I believe it's pretty simple in the mk1s... you're not wrong about auto electrics charging an arm and a leg :\
    Jan 2010
    Baulkham Hills
    mmmm manual would be very helpful... will get one tomorrow
    Sep 2009
    Chillaxing in Tas
    txt me when your free, ill come lend a hand mate. I also got a manual you can borrow
    <space for rent>
    Jan 2009
    south west sydney
    anyone know of a pdf version of a manual?
    Jan 2010
    Baulkham Hills
    DAN you are a legend will be a saturday due to work.. is that ok? i'll look at whats on in the coming weeks and messo you oh and mike1, i have also been searching for one! i have the fun haynes manual PDF for a mk2 golf and mk2 jetta... but can't find mk1...
    Sep 2009
    Chillaxing in Tas
    No worries josh, Just Chuck me a few bucks fer fuel, or a 6 pack and we can make a day of Mk1 Love
    Just pm me if you need any tools or anything.
    <space for rent>
    Jan 2010
    Baulkham Hills
    Sounds like a great day to me man mint. Oh yeah will need some tools. How much do you reckon we can get sorted with just the two of us? How about sat 24th? Two weeks away?
    Sep 2009
    Chillaxing in Tas
    if its a nice day, and all goes well we could get alot of it done, ive pulled 3-4 dashes out so i know my way around them now
    Just send me a txt and pm the friday before and ill get all the tools and **** in car
    <space for rent>
    Perth. WA
    Wiring on a 76 is unique to that year or earlier only, if the latter dash from the GLS is a different year ( likely) then you will run into issues, You will need a good wiring diagram from each year to see what you will have to relocate ( remove wires from plug positions and replace in different positions)
    The 76 uses beetle wiper and indicator stalks, thaty have different pin positions for the later plugs and fuse box layout.
    The warning lights could also be different from the early to the later dash, includes the foil circuit on the back of the cluster.
    Fan switch, blower motor are different to
    Been there and done this... get ready for a headache.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
