Page 10 of 14 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 134
Thread: The Danish mk1
  1. #91
    That's why God invented flares.
    The Danish mk1-1-31-jpg
  2. #92
    Jan 2015
    Denmark
    Apparently that God bloke is a wise person. But I don't want to use flares. I want to keep the car stock. Except for the engine obviously...
    If the wheels won't fit, I'll be using them on my daily driver. (Vw Up, do you guys even have those?)
  3. #93
    Sep 2012
    Melbourne, Vic
    Quote Originally Posted by Browneye View Post
    Et28 is massive! No wonder they look like they won't fit
    Sent from my D5833 using Tapatalk
    Et28 should fit easy. I have 15x7 et25 on the fronts 0deg camber which only just rub on big bumps!
    1982 Mk1 Golf GTi
  4. #94
    Jan 2015
    Denmark
    Great! Thanks fammo!
  5. #95
    Feb 2013
    Melbourne SE
    The 15x7 et13 I'm running rub in the rear fairly consistently. Just a word of warning if you plan in keeping stock guards
  6. #96
    Jan 2015
    Denmark
    There is still a big difference between ET 13 and ET 28. Time will tell if it's gonna be okay. But if they rub, I'm not gonna use them.
  7. #97
    Feb 2013
    Melbourne SE
    Oh whoops there's a brain fart on my part. Of course et13 would poke more than et28. My mistake
  8. #98
    Jan 2015
    Denmark
    How about tires? I'm thinking about running 165/50's. That much stretch would make them more likely to fit. But... It does look a bit silly when the car isn't slammed...
  9. #99
    Sep 2012
    Melbourne, Vic
    Quote Originally Posted by mads_christ View Post
    No probs, also running 195/45 so a skinnier tyre would work even better. I have 15x7.5 rears et18 which also only rub on big bumps. Again, if I folded the lips up they wouldn't rub as they only just touch.
    1982 Mk1 Golf GTi
  10. #100
    165 is very narrow, especially on a 7 inch rim. Not recommended for daily use because it requires a fair bit of stretch to seal properly.
    Normal tyre size is 195x50x15 so you can go 185 or 45 profile if you need more clearance.
