1.8L hands down if you get the weber set up well
I got a 1.8L with stock carby, and extractors and its miles in front of the old 1.6L![]()
Hi Dubbers!
Question: I have a Mk1 golf with a stock 1.6 motor. I have recently aquired a 1.6 Heron with K Jet and a 1.8 8v with Weber Carbi.
I'm wanting to know which motor would be better for my Daily Driver to give great performance & driving pleasure?
No technical babble... just an honest opinion!
Dave
<space for rent>
IF you can get the heron set up and running properly on Kjet, I'd go for that. But it's hard to find people that can tune it properly.
Same goes for the carb really. If you can get it running & tuned nice, the 1.8 will give it a nice bit of power and make it an entertaining drive, but the 1.6 would probably rev harder!
Why not 1.8 with Kjet?
dont see difference in revs between the 1.8 and 1.6 to be honest.
Still pull 6k easy with the 1.8, the old 1.6 would do 6500 but would loose power at 6k.
<space for rent>
Can that be done? Can the Kjet be used with the 1.8?
There is no substitute for cubic inches or in this case cc's. Having said that is the 1.8 a GTI engine or a lesser tune.
Your question was which engine was best for a daily driver.
The 1.8 has more torque and therefore as a daily driver will feel better as it will pull better from lower revs meaning less gear changes. I put a 1.8 into one of my Mark 1's many years ago. It was an early solid lifter motor. I put a 'G' grind GTI camshaft in it with a Passat TS manifold, Weber 32-36 DGAV carby and extractors. It was perfectly drivable and had heaps of performance.
To my mind it was the perfect bang for buck upgrade because I didn't have to bother with fitting fuel injection, new fuel tank etc. It was a straight drop in conversion.
I also had a 1.8 GTI (Kjet) in a Mark 1 at the same time which had a cam and extractors and there was little to choose between them in terms of performance.
Heron engines are also much rarer and more expensive to source parts. Plus, if you ever want to get that little bit more out of it, you may as well start with a "normal" type 8v. Everything is cheaper for them and they will make more power more easily.![]()
