Results 1 to 2 of 2
Thread: cv shaft lengths
    sydney
    cv shaft lengths
    put a later model 5 speed in the car, probably out of mk3 with the 100 mm cuplinks are the mk1 shafts compatable with the later gear boxes?
    i'm asking this because i cracked the bearing cage on the inner cv which means that the outer section of the cv joint might not be in line with the inner section.
    i have a feeling the distance between the the two couplinks on the later model is wider than the earlier model gear boxes
    Camden, Sydney
    The cups are all the same size. Distance is the same.
Similar Threads
  1. Diesel injector pump seals
    By hiho in forum Diesels
    Last Post: 19-12-2010, 02:18 PM
  2. Replies: 1
    Last Post: 02-11-2006, 08:05 PM
  3. Injector Pump Leak and movement - Main Shaft
    By hvellacott in forum Diesels
    Last Post: 28-09-2006, 07:20 PM
  4. VR6 RHS drive shaft removal
    By MartiniOlive in forum Mk3 Golf & Vento
    Last Post: 26-04-2006, 01:05 PM
