Results 1 to 2 of 2
Thread: cv joint question?
    cv joint question?
    i have a south african citigolf, it came with 100mm inner cv's, does this narrow down the options for the outer ones. got a noisy one and want to replace outer joints and all the boots. does anyone no where to get them from. i also need a clutch kit, would it be 210mm ,motor came from a aussie mk2 gti. while i'm here ,does anyone know where the compression changes in 1800 engines is made. is it the cylinder head chamber size or the piston shape. i think ive given up some power with this engine change. it seems to run well, but doesn't have the same snap when opening the secondary's . any way hope someone can help. cheers
    Perth. WA
    If the inners are 100 , then likely the outers will also be 100 's ( unless there has been a trans swap at some point )
    You can try repco, malz etc then compare prices with GAP or any of the overseas suppliers. I would look at GAP, rock auto, parts4vw's etc for the clutch stuff unless you go local and have yours rebuilt.
    Comp test your engine first to get an indication on its condition, then get a dyno tune. Go from there.
    HTH man ;D
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
