Lock Thread, and slap your face for being a tool.... ??![]()
(as a temporary solution to ride height and handling issues)
what are your thoughts?![]()
<space for rent>
Cannot even be bothered facilitating a meaningful reply.
If you cut a standard spring... say... in half, you're effectively doubling the spring rate.
Add to that the standard length of the shock's stroke and you'll have some seriously whack handling.
$700 is not a lot of money to spend on coil-overs, albeit 'low quality' ones.
There's far worse things than having a stance impaired vehicle.
spring should be held captive at all times.
Thats main reason why they so bad,
But lower springs usually = stiffer rate to stop car bottom out..
So standard spring = soft + cut 2-3 coils off = still soft spring and a bouncy ride which will bottom out bad.
Anyway, leave now and hide.... we might forgive you![]()
<space for rent>
do it.![]()
IH8
Explain to me how it doubles spring rate??
If a stock spring is 4kg and you cut it, it dont become 8kg.... its still the stock 4kg
<space for rent>
