Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Cut Springs
    Jan 2009
    Hobart, TAS
    Cut Springs
    (as a temporary solution to ride height and handling issues)
    what are your thoughts?
    Sep 2009
    Chillaxing in Tas
    Lock Thread, and slap your face for being a tool.... ??
    <space for rent>
    Apr 2009
    Newport, NSW.
    Quote Originally Posted by dviflx View Post
    What have you started...
    Jan 2009
    Hobart, TAS
    Quote Originally Posted by GRN_VAGN View Post
    hahaha yeah wouldn't be suprised
    Aug 2009
    Cannot even be bothered facilitating a meaningful reply.
    Jan 2009
    Hobart, TAS
    Quote Originally Posted by mrlex View Post
    well, you know. I'm broke, and my golf rides and handles like an elephant.
    I'm after opinions positive or negative
    Aug 2009
    If you cut a standard spring... say... in half, you're effectively doubling the spring rate.
    Add to that the standard length of the shock's stroke and you'll have some seriously whack handling.
    $700 is not a lot of money to spend on coil-overs, albeit 'low quality' ones.
    There's far worse things than having a stance impaired vehicle.
    Sep 2009
    Chillaxing in Tas
    spring should be held captive at all times.
    Thats main reason why they so bad,
    But lower springs usually = stiffer rate to stop car bottom out..
    So standard spring = soft + cut 2-3 coils off = still soft spring and a bouncy ride which will bottom out bad.
    Anyway, leave now and hide.... we might forgive you
    <space for rent>
    Sep 2009
    do it.
    Sep 2009
    Chillaxing in Tas
    IH8
    Explain to me how it doubles spring rate??
    If a stock spring is 4kg and you cut it, it dont become 8kg.... its still the stock 4kg
    <space for rent>
