Seriously???
Great results pal. A true testament to your build quality , and beautifully welded manifold, that it survived the days punishment and performed so well.
Great work , keep flying the mk1 flag.
Have never done a track day with a car or a motorbike, but just going to give some constructive criticism. If you turn half a second later and keep it as smooth as possible instead of jolting side to side to keep it on the track I reckon you might be able to hit 1.09 or even 1.08
Like I said never done it before and I think you did really well. Just something to think about for next time.
Only The Good Die Young 45
For a better ride, go WIDE!!!
VS Commodore V6 Berlina- FOR SALE
1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
Thanks guys. Alex I still love the beautifully welded manifold.
Mk1@4Motion, you better tell the WTAC charade driver his lines are wrong too, what a coincidence we’re both making the same mistake!
You wouldn't believe how quick this Mk1 is from the outside. In car cameras don't really give the right impression of speed. Torque steer and sliding under brakes is the main reason for the squirrelly looking video. Half a second later braking would have you off the track without a doubt.
#impressedwiththespeedofit
Not braking half a second later, just turn a little later and try pick a line and stick to it. Thats all I am trying to get to. But like I said, your times are fast and would have loved to see it live. But just something to think about.
Thanks h100vw.
Mk1@4motion, what you are seeing jumping around in the 1st video is the forward facing camera itself, it’s not the car. The camera was shaking a lot. As for when to turn in, if you don’t know the track, how could you possibly know the lines? Now I posted these videos to show my car doing what I built it for. If you want to critique my driving, at least look at the back camera view, that camera is not bouncing around (and funnily enough, neither is the car!). Better still, post up some footage of you cracking 1:10 in your mk1, showcasing this ultra-late-apex-super-steady driving technique you speak of. Now that actually would be constructive. Just something to think about..
So at the last track day I discovered that my brakes are getting towards their limit. They definitely got too hot, and I had to get the front discs machined as they were glazed. So it was time to set up some ducting to get a bit of air-flow into the front brakes.
After some investigation it seems the go is to get air flow right into the inside hub part of the rotor as much as possible. The vented rotor acts like an air pump, pumping from the centre and outwards through the vanes of the rotor, so you want to get as much fresh air in there as possible. Seeing as though our calipers are at the front of the wheel hub there isn't much room left, and after my first attempt of routing piping to the rear section of the brake backing plate failed, I was forced to re-try going into the front, just above the calipers. There is just so much movement going on in this area, suspension articulation, struts turning, sway bars, brake lines, wheels swinging, you just cannot get past all of this with decent sized ducting. I was forced to route to the front, so I went from 3" down to 2.5" ducting to suit the biggest pipe I could get into the area.
Here is a modded backing plate. The larger 3" hole was my first attempt. I decided to keep the hole there as this will help vent some of the heat from the inside face of the disc, which tends to get hotter than the outside which gets more airflow through the wheel.
Here it is mounted, you can see a lot of air can get right into the inside of the hub
I had to do some fibreglass mods on the front air dam to create 2 openings.
Here is the routing on the passenger side. I'll eventually get rid of the zip ties and come up with something better
After some test drives, no rubbing at all! If you look closely though you can spot the orange ducting in the wheel well, and in some light it stands out. That should get a few observant spotters wondering what the hell is going on in there
Awesome work mate! Have never really seem anything like that before. My track civic actually has the same issue you're describing, let me know how you go with the new mods at your next track day!
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
I'll let you know shortly as I plan to go down to wakefield in the next couple of weeks. One of the better DIYs guides in my searches was actually a Honda S2000 guy who set it up and tracks his car a lot. He reckoned it prolonged pad/rotor life, and performed noticeably better. It can be the difference between keeping your pads in their optimal heat range, or getting out of that range. My current wilwood pads drop off torque at about 370-400C. I have no idea how hot I am getting them, but it must be more. Mind you last time my car was double entered so it had less time to cool. You can get a paint that you put on the edge of the disc which discolours according to max heat which would be useful.
