76ers didnt have the light. Someone must have fitted a later instrument panel.
well, i start to work out several non-working lights in the cluster, they don't affect the car but I just feel something is missing
First is parking brake light not working. people in other forum mention there is a switch under the handbrake, but I couldn't find any. Is this something diff from aus mk1 and other country ?
Is there any fuse involved, pls help![]()
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
My '76 has no handbrake light either.
The cluster is pretty dim by modern standards so you will definitely notice when they are missing. Easy to change one the cluster is out..
I caught myself driving with the brake on, no lights, so I am assuming no...
If its a 76er, once again, they didnt come out with the handbrake warning light, if its a locally assembled. The German 76 GLS models had the light from memory and I have only seen 1-2 of them.
If it worked once then someone has fitted a GLS cluster and wired it up. If it is wired up then it may be dodgy as the ones with the light also had a problem light in the same unit and the wiring for them is a bit more extensive
