Results 1 to 9 of 9
Thread: couple of electrical issues
    well, i start to work out several non-working lights in the cluster, they don't affect the car but I just feel something is missing
    First is parking brake light not working. people in other forum mention there is a switch under the handbrake, but I couldn't find any. Is this something diff from aus mk1 and other country ?
    Is there any fuse involved, pls help
    Apr 2006
    Hobart,Tas
    76ers didnt have the light. Someone must have fitted a later instrument panel.
    Jul 2005
    Newcastle, NSW
    My '76 has no handbrake light either.
    Gosford Central Coast NSW
    Quote Originally Posted by mikinoz View Post
    good for fooling your passenger at night about sudden u-turns.....
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Mar 2006
    brisbane
    The cluster is pretty dim by modern standards so you will definitely notice when they are missing. Easy to change one the cluster is out..
    Quote Originally Posted by gtimk5 View Post
    Really ? i roughly remember it went ON sometime ago....
    Jul 2005
    Newcastle, NSW
    I caught myself driving with the brake on, no lights, so I am assuming no...
    Apr 2006
    Hobart,Tas
    If its a 76er, once again, they didnt come out with the handbrake warning light, if its a locally assembled. The German 76 GLS models had the light from memory and I have only seen 1-2 of them.
    If it worked once then someone has fitted a GLS cluster and wired it up. If it is wired up then it may be dodgy as the ones with the light also had a problem light in the same unit and the wiring for them is a bit more extensive
    Apr 2006
    Hobart,Tas
    I hope you didnt do that with Imps too mate.
