Results 11 to 20 of 33
Thread: Cooling
    syncro Guest
    Good article.
    I have a Volkswagen so I use Volkswagen coolant.
    If I had a Holden I would use Holden coolant.
    If I had a Toyota I would use Toyota coolant.
    If I had a Ford........ no I wouldn't have a Ford.
    Allens Rivulet, Tasmania
    alright, ill give it a crack.... I just find it odd that all 3 golfs ive owned have has the same problem. A problem that no one else seems to have. What am i doing wrong?!?!?!
    syncro Guest
    Quote Originally Posted by el_foolio
    OK What Golf/engine is it?
    First, remove radiator hoses and the two heater hoses at the engine.
    Get your garden hose and flush out at every oriface until the water comes out clean (make sure heater is on). Then flush back the other way. Then fill with VW coolant and distilled water.
    Let me know what you find.
    Mk1 1600. Yeah done that many a time with all 3. sat there for hours flushing it. mk. where can i get vw coolant?
    syncro Guest
    VW dealer.
    When do they overheat?
    Are you loosing water?
    Apr 2006
    Hobart,Tas
    You can get G11 coolant from most VW workshops
    overheats when im driving it. No, not losing any water. Inclduing your Vw Workshop gtimk5??
    syncro Guest
    What speed/stop start traffic/hills/highway......?
    Apr 2006
    Hobart,Tas
    Yes, I hve G11 coolant. Have you checked the thermostat? If there isn't one fitted than it will overheat. A faulty radiator cap will cause it to o'heat when sitting idling. You have had this problem for a while now, haven't you?
    Apr 2006
    VW Race HQ - Sydney
    Where do you get g11 from , VW stopped selling it 3 years ago , superceded to g12+
Similar Threads
  1. My Corrado G60
    By OEM G60 in forum Corrado
    Last Post: 12-10-2011, 11:49 AM
  2. Flashing cooling system light??
    By pommy_golfer in forum Mk3 Golf & Vento
    Last Post: 13-03-2007, 06:21 PM
  3. PAS Cooling Pipe
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 22-10-2006, 07:58 PM
  4. Diesel cooling system
    By smithy010 in forum Diesels
    Last Post: 21-07-2006, 01:17 AM
  5. 76 MK1 4 door
    By worm in forum Mk1 Golf
    Last Post: 10-05-2006, 10:35 PM
