Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Cooling
    Allens Rivulet, Tasmania
    Cooling
    hey all. had a few problems with cooling. what cooling method do you guys recomend? Straight water? Coolant? If so what colour/type coolant?
    syncro Guest
    Genuine VW. G12+ or G13 or whatever it is called.
    Distilled water from Franklins.
    Apr 2006
    Hobart,Tas
    On an older Golf I use coolant, just normal from Repco or wherever. 2,1/5 litres snould do it. The rest just crystal clear Tasmanian tap water! I only use G11 or G12 on the 90s onward VWs according to what the model specified.
    syncro Guest
    Quote Originally Posted by gtimk5
    Why
    Apr 2006
    Hobart,Tas
    Hi Syncro. I would say 99% of Mk1 golfs down here have never had G11 ect. in them. I have nothing against using the later coolants but do they mix with a car that has "normal" type coolant in it? Cost is also an issue for some of the earlier vehicle customers.
    Hey, thats just what I have always done
    syncro Guest
    Better question is why not use it? The cost is difference minimal.
    G10 was the original coolant and was superceeded in the '80s by G11 then G11 V8, then G11 V8B etc. It's an evolution thing......
    imported_brackie Guest
    Cooling system advice
    Rather than me posting advice directly you may want to read this article I wrote a few years back. It refers mostly to the Rover alloy V8 but some of it applies to VWs.
    http://www.discoveryauto.com.au/page4.htm
    Tear it to bits! It's a free country
    A couple of years back (or so) there was a current affairs "Lets Expose It!" type programme...can't remember which one... that did tests on coolants. The results were very surprising with some of the cheaper coolants coming out the best. I don't think "Techalloy" (sp?) did too well. Also "Choice" magazine tested them. My advice would be to go genuine. As syncro says coolants have changed over the years so get the right one for your model.
    im currently running green coolant. not sure of anything more than that. its repco stuff. but every car mk1 ive run that in has had overheating probs. so i just thought that may have something to do with it
    syncro Guest
    Except when I first bought my Golfs, I have never had overheating problems. Australian Golfs have very large radiators.
    Camden, Sydney
    Nice article Peter
    We`ll have to get more informative articles like that on here when we update to the new server.
Similar Threads
  1. My Corrado G60
    By OEM G60 in forum Corrado
    Last Post: 12-10-2011, 11:49 AM
  2. Flashing cooling system light??
    By pommy_golfer in forum Mk3 Golf & Vento
    Last Post: 13-03-2007, 06:21 PM
  3. PAS Cooling Pipe
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 22-10-2006, 07:58 PM
  4. Diesel cooling system
    By smithy010 in forum Diesels
    Last Post: 21-07-2006, 01:17 AM
  5. 76 MK1 4 door
    By worm in forum Mk1 Golf
    Last Post: 10-05-2006, 10:35 PM
