Results 21 to 30 of 33
Thread: Cooling
  1. #21
    Jul 2005
    Newcastle, NSW
    G whatever...
    use something...
  2. #22
    imported_brackie Guest
    Oh dear
    "Aim the extinquisher at the BASE of the fire......."
  3. #23
    syncro Guest
    Quote Originally Posted by Bug_racer
    Where do you get g11 from , VW stopped selling it 3 years ago , superceded to g12+
    Tasmania
  4. #24
    Apr 2006
    Hobart,Tas
    the coolant I have is made by Febi/Bilstein, GO11 ABC A1, tis blue
    the other is made by Hepu G012 A8D, pink
  5. #25
    Maitland, NSW
    i think that man may have had more than one extinguisher! i dont think i cant spell.. or use proper engrish..
    i must have mechanic blood in me!
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
  6. #26
    Golfwise Guest
    Was nice 39 Ford ,did you get that fire out Mik ?
  7. #27
    May 2006
    Queanbeyan NSW
    Mk 1 cooling
    I have run the green coolant from Castrol or Valvoline for nearly 25 years in a Mk 1, no corrosion problems. Just buy a 2l container and top up with water. Replace every couple of years. The temp gauge will often hit the red though. I used to worry about that a lot early on, until I hooked up a pressure gauge to the cooling system and saw that it was only sitting around 60kpa when it did this. It would peak at 70kpa occasionally in summer stopped at the lights. It has never been near the 100kpa pressure where the cap will let go, so I haven't worried about it for over 20 years. Its never boiled.
  8. #28
    Allens Rivulet, Tasmania
    well, ill be into your workshop in the not too distant future!
  9. #29
    syncro Guest
    The temp gauge should never get into the red. If it does then there is something wrong.
    I had one problem that was hard to find.
    Driving along at any speed over 40k was OK.
    When stopped was OK.
    Driving slowly it overheated.
    Have a guess.
  10. #30
    Camden, Sydney
    Quote Originally Posted by syncro
    Have a guess.
    Fan was running in reverse?
Similar Threads
  1. My Corrado G60
    By OEM G60 in forum Corrado
    Last Post: 12-10-2011, 11:49 AM
  2. Flashing cooling system light??
    By pommy_golfer in forum Mk3 Golf & Vento
    Last Post: 13-03-2007, 06:21 PM
  3. PAS Cooling Pipe
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 22-10-2006, 07:58 PM
  4. Diesel cooling system
    By smithy010 in forum Diesels
    Last Post: 21-07-2006, 01:17 AM
  5. 76 MK1 4 door
    By worm in forum Mk1 Golf
    Last Post: 10-05-2006, 10:35 PM
