Thanks. I am looking for the same information?
James.
Hi All
Which coolant should we be using in our Mk 1's, G10, G11, G 12 or G12 +?
Planning to do a coolant flush soon
Thanks
James.
Didnt think it mattered ?
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Any of the generic green stuff is fine.
Careful using G12 etc, it can eat your water jackets from what i've seen..
I use G12+.
Used to use G11, but VW upgraded that to G12+ a number of years ago.
Have had no troubles with eating water jackets (maybe that was the old G12)
The generic green stuff should be fine - should do no harm, should provide the necessary anti-corrosive effect if used at appropriate concentration and changed every couple of years.
My memory is that plain water eventually led to corrosion of one of the pipes (in about a year)
If you don't know what's in it do a flush first then run it 30% glycol (concentrated coolant mixed as directed).
A lot of the corrosion stories have come out of people mixing early and late coolants (or not fully flushing G11 prior to pouring in G12), which really is a recipe for disaster!
I use the generic green stuff in all of mine but I do change it at least annually.
I seem to have the cooling systems apart pretty often so the coolant is always getting refreshed.
The Passat in particular had a putrid cooling system and had radiator stop leak put through it by a previous owner.
To get rid of that gunk I've had to replace all the hoses, radiator and heater core.
That car is getting a flush treatment and coolant change every 3 months for the first year.
Likewise with the MK1 I'm racing I just use the generic green stuff although I probably could/should run G12 as it's a 2.0 bottom end.
Again though I'm constantly pulling this apart so it probably gets a coolant change every 6 months or so any way.
Neither of those motors seem to be suffering any corrosion issues but they are receiving a pretty high level of maintenance.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Same here, generic green stuff, i usually flush every 12 months, more lately due to having to replace cooling parts, and pulling engine out ect.
<space for rent>
Generic. Actually flushed and replaced the coolant in the mk1 passat on friday. I used Mitsubishi premixed coolant that we use at the workshop. But I have always used generic.
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
