pre-review
RIGHT!
well, i took delivery of the TECHNIKS (thats hottuning's brand) coilovers a little while back and have only fitted the rears so far (gotta fix up my front strut towers before i fit the fronts).
before, i had koni adjustable rear struts and king springs. the shocks were set and the hardest setting. (bump)
the techniks are more pliable than the koni's over rough bumps, but feel like they offer a faster rate increase with travel, since the small spring is not completely squished when stationary, there is a little bit of "soft" travel before the hard big spring kicks in. this makes for a great combination of straight smooth road comfort and good anti-roll characteristics. certianly less weight transfer than before.
the bodies are also able to be dismantled completely which means that different shock's could be fitted no problems, and ofcourse different springs if one so wished.
will comment further once the front is fixed up. so far, i'm very pleased.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
