Results 1 to 10 of 13
Thread: clutch slip.... BAD
    clutch slip.... BAD
    i cant floor the mk1 because of terrible clutch slip.
    clutch is adjusted all the way out so it cant be that.
    AND its a near new clutch plate.
    any ideas?
    Eastern suburbs of Melb
    take the cable off the box...start her in gear and drive it with no cable see if it slops then....if it does unfortunately you will need to change your clutch
    Gosford Central Coast NSW
    Quote Originally Posted by GoLfMan View Post
    any ideas?
    c'mon mate, we need more info than that.
    you say 'near new' - so whats that? 2 weeks, 6 months?
    who replaced it? what was replaced - did you change pressurep late aswell, and have your flywheel machined, or was it just the friction plate.
    did you change the crankshaft big end seal?
    does your gearbox leak oil
    is oil dripping out of the bellhousing?
    do you have the appropriate covers on the end of the bellhousing to prevent water/oil/grip from entering?
    the answers to all these questions may yeild your problem....
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2007
    Eastern Suburbs Melbourne
    Drop the box and do some investigationing.
    My money is on some contaminate on the clutch
    i like volkswagens
    it could be your clutch fella
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    dropping the box will have to happen soon...
    no machining of the pressure plate or flywheels were done and I replaced the clutch myself!
    near new as in, less than 2000kms on it!
    Apr 2006
    Hobart,Tas
    Time to do it again then mate, and do a double check to the list of gldgti's.
    Should get 100,000 kms out of a clutch job if you make sure there are zero oil leaks.
    Quote Originally Posted by gtimk5 View Post
    I've got a pretty warm motor in there at the moment, can the stock clutches take uprated power??
