Quote Originally Posted by wai View Post
If the clutch is now permanently disengaged, it is unlikely to be a broken clutch cable as once broken, the clutch would be engaged. It sounds more like the clutch centre has failed. This would be why you have no drive and no pedal.
I heard the bang as I was shifting down gears, i'm not sure when it happened as i was changing gears at the time, but i think it may have been as I put my clutch in to change from 3rd to 2nd, so i'm fairly sure it was mid-change. Never the less, tomorrow afternoon i'll be able to pull it off and verify. Pretty straight forward exercise removing the cable I assume?
Just to clarify. I can't get into any gears, no clutch pedal. So the clutch center is an option. Thank god they're cheap from ECS if it comes to that...
