Buy a new one quick! You've got about a day till it snaps.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
****! Thanks Pete ha ha aaaaagh the joys of old cars
Yeah but the cable you buy will last another 30 years. Not a bad fault rate![]()
7? MK1 Caddy
12 Amarok
time for a new cable my friend. When you put the new one in, invest in some motorbike chain lube (in a spray can) and spray in from each end.
Also the rubber bush where the cable meets the gearbox might need replacing if it has worn out. Levae that go and the cable might start cutting into the bracket on the side of the gearbox where the cable attaches.
Have fun replacing it
1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
Lithium grease (spray) is good for cables, is it not?
I don't know, some research might be warranted. Silicone spray also works a treat also and less smelly than oil based sprays
I was recommended to use Lithium Grease specifically for power window regulator cables. Worked very well, messy as hell though!
Not that we have to worry about power windows and those sort of things in this forum...![]()
