Results 1 to 10 of 11
Thread: Clunking when turning right
    Sep 2008
    Launceston
    I've have an issues with my gf's cabbie. When turning right there is a constant clunking noise. Coilovers were installed yesterday along with complete wishbones, ball joints, and top mounts. I was hoping this would help however the noise is still there.
    I know it's not the axle knocking on the wishbone as the noise was there with standard suspension. It also doesn't sound like the normal noise I am used on other vehicles with a dodgy cv joint but should this be where I look next?
    Another thing is that it doesn't seem to make the noise until you been driving for a couple of minutes.
    Nick
    Jul 2005
    Newcastle, NSW
    Sounds like the CV to me, if it is constant - or the driveshafts might be fouling if you have lowered it THAT far and it happens when there is suspension travel!
    Sep 2008
    Launceston
    Thanks mate, Sounds like the cv then as it was making the noise before the coils went in. Who in aus would carry cv's (apart from a dealer) and any idea of cost?
    Jul 2005
    Newcastle, NSW
    Ring andrew robinson automotive in hobart or GTI imports Glaston. Google them.
    Sep 2009
    Chillaxing in Tas
    PM'd you, ....
    <space for rent>
    Feb 2007
    If its always when your turn right and not when you turn left its because you've gone to low. The drive shafts need to be shortened. Happened on my mk1 and mk2, the more i raised it the more the noise went away
    Jarrad has looked in to it, ask him.
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by Spyda View Post
    he said it happened with the stock suspension in it aswell, so cv binding wouldnt be it...and i mean as in lowering the car causing it.
    A stuffed CV maybe though
    <space for rent>
    Mar 2011
    Bunvegas, Western Australia
    If it is a stuffed CV, which one do you replace then? The inner, or outer? Just I've started to have similar noises occur and I'd like to order the parts as soon as possible so I can install all the parts I have stockpiled in one hit!
    Oct 2010
    Melbourne, VIC
    Take the shaft with the joints to a CV specialist (ask a good mechanic to suggest one) and they can usually recondition them
    Resident grumpy old fart
    Mar 2011
    Any idea of what that would be cost wise? Because if it's close enough to the price of new ones I may as well just replaced them..
    Definitely another idea though..
