Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Cheap brake upgrade
    Yep, read that a few times in preparation. Great article.
    One thing I can't work out is my Polo has really good brakes yet they aren't any bigger than the Golf's. The Golf by comparison has crappy brakes even with the GTI disks and calipers up front. I'm hoping it's the brake booster that makes the brakes so good.
    Jun 2007
    Eastern Suburbs Melbourne
    brake booster adds alot of feel back into the system.
    Especially considering the mk 1 stuff, is about 4 centuries old by now, and most probably still original stuff.
    Should have a bigger MC too, which will help give greater stopping force
    i like volkswagens
    Jan 2006
    Ballarat, Victoria
    I think there are two issues of difference between the Polo brakes and Mk1 Golfs. Most significantly is the pull rod and bell cranks that transfer the action of the brake pedal across the car to the booster and master cylinder. A lot of feel or control is lost here. I reckon I can feel the rod bowing when I push the brake pedal hard - there is a sponginess when braking hard.
    The second issue I suspect is crappy brake pads - cheap or non-performance pads that have too low a coefficient of friction - that require more shove on the brake pedal which then makes the pull-rod and bell cranks even more of an issue.
    A cheap brake upgrade would be to put some really good pads on - eg Ferodo DB2500
    Thanks for all the advice guys. I'll do the brake booster and pads first then build and fit a solid bar to replace the pull rod and cranks.
