Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Carby choices
  1. #21
    Boronia VIC
    Quote Originally Posted by 76' Oettinger View Post
    Excellent.. All I need to do is get a TS Manifold and steal the DGAV from my girlfirends RS2000 mwahaha Haha, Can anyone tell me what the performance is like with a Dgav setup on a 1600?
    I've been running one for a while, the 1600 it was on was stuffed but the carby let it rev beyond 7000 RPM. (Obviously I didn't care about this motor!). The motor didn't have a lot of compression which is probably why it didn't pull too well from idle.
    In a traffic light drag race you could light up the 195 G'Grids if you went heavy on the clutch.
    Compared to the stock carby, it actually idles properly! The manual choke works well although there's also versions of this carb with electric or water based auto chokes.
    A couple of weeks ago I swapped the dud 1600 out for a Cordoba 1800. I put the same carb back onto the fresh motor. Wow! Now everything is working as it should (almost) take off from idle is smooth and you can really feel the secondary venturi kick in when you floor it. On a wet road you can break traction in first or second by squeezing the throttle.
    The problem I've got now is that I've got a bit too much fuel pressure because I installed an electric fuel pump. There's a pressure reg on the way in the next couple of days. The effect of this is over fuelling at low RPM when the fuel pressure is too much for the needle valve in the carb. It's making tuning a little tricky and it can sort of chuff back out the aircleaner when you shut it off. The pressure reg should sort all this out.
    Pete
  2. #22
    76' Oettinger Guest
    ha, nice.. can't wait.. should'nt be too hard to track down a TS Passat manifiold in Tasmania.. And 4 Cylinder Cortina's are everywhere so it should be a good start to modding my LS..
  3. #23
    burnie,tas
    if you hit a dead end with the ts passat Manifold an audi fox one should be the same correct me if i m wrong
    where in tassie are you
    1977 2dr golf gls (Gti look a like with 2e convertion
    1978 Golf Gti barn find
    2013 Amarok Highline daily
    2017 Golf wagon wife’s daily
  4. #24
    76' Oettinger Guest
    Quote Originally Posted by hazards_golf74 View Post
    I'm from Down south, Hobart. Audi Fox huh? I need to start hunting around to a TS manifold.. haven't managed to even start looking.. But a wrecker should have the Cortina Weber.. I hope
