Results 11 to 20 of 24
Thread: Carby choices
    Feb 2007
    Eastern Melbourne, VIC
    So how is economy on a 45dcoe compared to twin 40's? Something i have to look at soon, my car just blew it's head gasket and i gotta get the next motor in.....that motor came at just the right time
    The Baltic Bruiser™
    syncro Guest
    I have heard a few reports that the twins are more efficient. I don't really know of anyone that has a single with a Lynx manifold that works properly. No3 always runs rich.
    Quote Originally Posted by syncro View Post
    its because the lynx manifold has a weird firing pattern, the dissi needs to be modified i believe
    I reckon it would be more of a case with the brake booster vacuum signal upsetting both #3 & #4 cyl's off #4. These manifold's are grouped as pair's eg. 1 & 2, 3 & 4 so 1 & 2 are basically on there own & are fine.
    You have to run the passenger side (3 & 4) mixture richer to even out for the brake booster vacuum signal on #4 the catch 22 is that #3 run's richer than the rest.
    With twin carb's you can tune out the descrepancy in #4. I've had to do this on my 2L excort with twin 40 dell's.
    Gosford Central Coast NSW
    Quote Originally Posted by GoLfMan View Post
    you'de need to do a lot more to change the firing order mate
    but no, it not necessary to do that - mollins setup seems to run just fine with his dcoe on lynx.
    got a TS manifold today (cheers loon ) so on the lookout for a dgav now.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    76' Oettinger Guest
    I'm guessing that a TS Passat manifold and a DGAV from a Cortina just bolt straight on to one another or is there a need for an adapter plate?
    Boronia VIC
    Quote Originally Posted by 76' Oettinger View Post
    That's right they were made for each other! No need for an adaptor plate.
    There is an adaptor that will allow the DGAV to go on a standard 1600 manifold, it's basically a funnel. I doubt performance would be fantastic.
    Pete
    76' Oettinger Guest
    Excellent.. All I need to do is get a TS Manifold and steal the DGAV from my girlfirends RS2000 mwahaha Haha, Can anyone tell me what the performance is like with a Dgav setup on a 1600?
    might be able to in a couple of weeks ()
    '99 A4 Quattro 1.8T
    76' Oettinger Guest
    Excellent.. Keep me posted.. i'm keen to try the set-up myself
