well i got a 24/24 here out of my old renault 15... im sure that'll bolt up
Yellow golf has an old grotty single throat Weber with manual choke. It’s ok but I figure it might be a good place to start for some cheap performance gain.
I grabbed the twin-throat Weber manifold off e-bay last week, so I am looking for something (second hand - but not too buggered) that would bolt up.
I was bidding on a rather nice DCNF till e-bay cancelled the seller’s membership (and all his sales) DOH!!!
So guys, what are my options (max budget for this mod approx $150)
C
It's been a while...
I have a couple in the for sales section
32/36 webbers good cheap option
mine off a 2l f eski jetted out
plenty of options in the parts for
sale as metioned
What is the difference between progressive and synchronous?? I know in principal but what about drivability? (Note that ecconomy is NOT an issue)
C
Edit: Still interested in opinions, but after a trip to Peter's Magic Carbie Box - I have a 32/36 in my hot little hand that should keep me out of trouble.
i've been wanting to redo my carbie to a webber but i have no idea what i need
can someone explain what needs to be changed? whats all the diff between the webbers??? very noob question, but this is my first carbie car!
Mine:2012 MY12.5 Amarok |Natural Grey |RCD510|Premium Bluetooth
Hers:2012 MY12.5 Passat TDI|White|RNS510|MDI|Premium Bluetooth|Park Assist 2 | Sports pack | Tints
Hi rexy we were running a dgav weber( bolts straight on) on the yellow car till we put twin dellortos on The carbies still here it will cost you postage if you want it contact me off line Trevor
MK1 RALLY CAR
SUPERCHARGED MAZDA323 AUTOCROSS CAR
I think that if economy is not an issue then some flat slide carbys (as seen on them there Le Mans Prosche racer thingys) are the order of the day.
MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
"Fit the gearbox ya bum." Loon - best post ever!
you need a different manifold that fits the carbie that you purchase, apart from that plug and play (make sure the jetting is right )Originally Posted by Darks RS
Thanks heaps Trevor, but I think I am set now thanks to the continued magic of Peter's back room.Originally Posted by gumbootracing
Mr Dark check out http://cgi.ebay.com.au/VW-GOLF-MK1-M...QQcmdZViewItem
Thanks all, I may go twins at a later date, I just have to keep reminding myself that this is not meant to be the "big bugdet" rally car (- John Rawson still has custody of that one ) it's just to punt around in at khana events etc
C
