Results 1 to 4 of 4
Thread: carbi plate
    burnie,tas
    carbi plate
    i got my ts passat intake and i got a 2 litre cortina weber(need rebuild and doen t have choke) but they don t fit so i wanted to put a renault 12 carbi (all they just needs a clean )on but i can t find a plate, so i can bolt them together any one know if ya can get them or will i have to make one
    1977 2dr golf gls (Gti look a like with 2e convertion
    1978 Golf Gti barn find
    2013 Amarok Highline daily
    2017 Golf wagon wife’s daily
    That's odd, as I've just fitted a TS passat intake & a 2L Escort weber & it bolted straight up.
    The only prob. is that there isn't much room for a air cleaner
    Gosford Central Coast NSW
    so did I.
    there are more than one kind of VW manifold to take multibarrel downdraft carbies, for instance there are several vacuum operated twin barrel solex carbies - the manifolds for these may not be correct for your webber.
    golfworx - on my car i have about 3mm clearance between the raintray and air cleaner. that is with a 32/36 dgv, and a 4mm isolator between manifold and carbie.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    burnie,tas
    thanks may mine isn t a cortina weber oh well i just make a plate
