Results 1 to 10 of 12
Thread: Car Won't Fire/start
    Mar 2010
    Perth
    I have a problem that i dont know how to fix!
    I got a new battery for my Golf, so now it cranks really well but i cant get it to fire up and start. Like i turn the key, the engine cranks for a few seconds and then gives up and doesnt fire!!!.
    What possibly can i check, as it is happening on and off, sometimes it starts and goes fine for a week, and then sometimes it doesnt want to start at all.
    Its not giving me much confidence to take it out anywhere in this state!
    Boronia VIC
    Try the points in the dizzy first, they need replacing/adjusting about every 12 months.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Mar 2010
    Perth
    Hi Peter, What do you mean by "Try the points on the dizzy first" do you mean just to check all the connections to it? and see if theyre connecting well?
    Ill go try that now.
    Mar 2010
    Perth
    Everything leading to the dizzy and all the leads to the spark plugs look good...
    Boronia VIC
    Look inside the dizzy. Take the cap off.
    Inside there is a set of contacts (points) that open and close as the engine rotates.
    These are what switch current to the coil which in turn produces a spark.
    The setting of the gap between the contacts is part of tuning these motors.
    Over time the points wear out through arcing. Usually the gap closes up due to deposits forming on the contacts.
    These can be filed off and the gap reset or they can be replaced.
    Try googling for "how to set points'
    Pete
    7? MK1 Caddy
    12 Amarok
    Boronia VIC
    Here you go,take a look at this. This is an aircooled motor but the points are the same.
    7? MK1 Caddy
    12 Amarok
    I have a problem as well! The car started to misfire over a few days and I was unable to start one morning and have not start it since. It cranks and have fuel.Is it common to have this simptons prior to this fault.
    Boronia VIC
    Yep, just means you need a tune.
    7? MK1 Caddy
    12 Amarok
    Perth. WA
    replied to the email Anton
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Mar 2010
    Perth
    Thanks for all the really helpful info there. Ill give it a go tomorrow and see how it goes!!! Hopefully a success
