Try the points in the dizzy first, they need replacing/adjusting about every 12 months.
I have a problem that i dont know how to fix!
I got a new battery for my Golf, so now it cranks really well but i cant get it to fire up and start. Like i turn the key, the engine cranks for a few seconds and then gives up and doesnt fire!!!.
What possibly can i check, as it is happening on and off, sometimes it starts and goes fine for a week, and then sometimes it doesnt want to start at all.
Its not giving me much confidence to take it out anywhere in this state!
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Hi Peter, What do you mean by "Try the points on the dizzy first" do you mean just to check all the connections to it? and see if theyre connecting well?
Ill go try that now.
Everything leading to the dizzy and all the leads to the spark plugs look good...
Look inside the dizzy. Take the cap off.
Inside there is a set of contacts (points) that open and close as the engine rotates.
These are what switch current to the coil which in turn produces a spark.
The setting of the gap between the contacts is part of tuning these motors.
Over time the points wear out through arcing. Usually the gap closes up due to deposits forming on the contacts.
These can be filed off and the gap reset or they can be replaced.
Try googling for "how to set points'
Pete
7? MK1 Caddy
12 Amarok
Here you go,take a look at this. This is an aircooled motor but the points are the same.
7? MK1 Caddy
12 Amarok
Yep, just means you need a tune.
7? MK1 Caddy
12 Amarok
replied to the email Anton
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Thanks for all the really helpful info there. Ill give it a go tomorrow and see how it goes!!! Hopefully a success
