Results 1 to 10 of 11
Thread: brake lights not working on 81 gld
    Aug 2009
    Torquay, victoria
    the scenario: brake lights are not working, globes are fine, fuse is fine so my guess is it is the brake light switch. there is no switch behind the pedal, i have been told this is located on the master cylinder???? not sure which plug it is or even if i am looking at the right thing. there is a plug on top, the side and something that is not even connected to anything. i have attached photos so u can see what i am looking at. please help!
    photo shows one on side and one on top
    photo shows one going nowhere
    Gosford Central Coast NSW
    hey mate,
    its definately the switch, and a common problem at that. i would suggest getting hold of a manula with wiring diagrams and use the colour codes to figure which switch is which. however, replace both, as its not much money to do so.
    i have seen setups with 3 connectors and setups with 2 connectos, and i am only familiar with the 2 connector setup - however you will be able to find out what you need simply by using a jumper wire to short both connectors one at a time and see which one turns the brake lights on
    HTH!
    PS - ring HSY autoparts for those sensors, thats where i got them last time. in sydney, 8339 8339
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Aug 2009
    Torquay, victoria
    what is the lead connected to nothing at all???
    Feb 2008
    Townsville QLD
    I thought this diesel section was for diesel related topics
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    its a mk1 diesel. fine by me.
    '99 A4 Quattro 1.8T
    Aug 2009
    Torquay, victoria
    Quote Originally Posted by vanDub View Post
    its a mk1 diesel mate, and if there ws a section that was brake specific i would have posted this thread there... but thanks for the creative input
    Canberra
    Would you have been happier if he had pointed out that there is a specific Mk 1 section ?
    Quote Originally Posted by lawny View Post
    if you mean that connector doing nothing under the washer bottle, its there on just about every mk1.... i think some car's had some other connector on the gb for something or other, but most didnt.
    nothing to worry about.
    '99 A4 Quattro 1.8T
