With digifant or K-jet injection?
Would it be easier to get some serious headwork done, that'd get you into the 150+ hp range.
Can you tubro a 2E?? with like a small stock mk4 turbo or something? i'm trying to brain storm but i know nothing about engines..
2012 Ford Focus - Panther Black
Previous - 1977 VW Golf GLS - 2E (beige beast)
Previous - 1976 VW Golf Ls (flipper blue)
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
yes, yes you could.
it'd be easiest to run standalone managment. Nearly everything else would need to be modified or custom. Far from a bolt on affair.
Ahhh ok. what can you do with a 2E to improve its performance?
wikipedia says the 2E is stock with 85kw.. as apposed to a mk1 GTI 1.8L that has 67kw. so surely a 2E in something as light as a 2dr mk1 would make a fair bit?
just say the mk1 2dr wieghs 760kgs (through deleting most of the interior.. and runs a 2E at 85kw.. thats a power/weight ratio of approx 1:15.7.. right?
those figures (assuming they are close to accurate would suggest enough power to compete with a mk4 GTI 20vT surely?
that set up (properly set up)_ would whollop most mk 4 gti's!
it'll even give standard mk 5's more than just a run for thier money.
There's plenty of potential going the NA route, before needing the added power of a turbo.
My 2E has a cam, dellortos and an 1800 head.
81kw at the front wheels.
It's got a bigger cam since it was last dynoed so it's got a little more now.
I'll get it retuned over Christmas and post the new numbers.
http://www.vwwatercooled.org.au/f55/...-13857-54.html
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Whats the sudden interest in 2E's Josh??
Did you end up getting Hennie's 2 door from down south?? if so, its plenty quick enough to get you in trouble
<space for rent>
7? MK1 Caddy
12 Amarok
HAHAHA
7? MK1 Caddy
12 Amarok
