Results 1 to 10 of 17
Thread: Can you tubro a 2E??
    Jan 2010
    Baulkham Hills
    Can you tubro a 2E?? with like a small stock mk4 turbo or something? i'm trying to brain storm but i know nothing about engines..
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
    May 2010
    NQ
    With digifant or K-jet injection?
    Would it be easier to get some serious headwork done, that'd get you into the 150+ hp range.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Jun 2007
    Eastern Suburbs Melbourne
    yes, yes you could.
    it'd be easiest to run standalone managment. Nearly everything else would need to be modified or custom. Far from a bolt on affair.
    i like volkswagens
    Jan 2010
    Baulkham Hills
    Ahhh ok. what can you do with a 2E to improve its performance?
    wikipedia says the 2E is stock with 85kw.. as apposed to a mk1 GTI 1.8L that has 67kw. so surely a 2E in something as light as a 2dr mk1 would make a fair bit?
    just say the mk1 2dr wieghs 760kgs (through deleting most of the interior.. and runs a 2E at 85kw.. thats a power/weight ratio of approx 1:15.7.. right?
    those figures (assuming they are close to accurate would suggest enough power to compete with a mk4 GTI 20vT surely?
    Jun 2007
    that set up (properly set up)_ would whollop most mk 4 gti's!
    it'll even give standard mk 5's more than just a run for thier money.
    There's plenty of potential going the NA route, before needing the added power of a turbo.
    i like volkswagens
    Boronia VIC
    My 2E has a cam, dellortos and an 1800 head.
    81kw at the front wheels.
    It's got a bigger cam since it was last dynoed so it's got a little more now.
    I'll get it retuned over Christmas and post the new numbers.
    http://www.vwwatercooled.org.au/f55/...-13857-54.html
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Sep 2009
    Chillaxing in Tas
    Whats the sudden interest in 2E's Josh??
    Did you end up getting Hennie's 2 door from down south?? if so, its plenty quick enough to get you in trouble
    <space for rent>
    Boronia VIC
    Quote Originally Posted by GRN_VAGN View Post
    Yeah, what he said.
    What you're not realising is that the 2E has a bucket load more torque than a 1600.
    Lane changes are done with throttle and under steer. Even with a mild cam, k-jet and a stock 1800 head I could break traction in third gear in the wet.
    7? MK1 Caddy
    12 Amarok
    May 2010
    NQ
    Yeah, what he said.
    Does yours run on the 4 into 2 exhaust mainfold Peter?
    And yes they are more of a torquey engine, I think max toque is at 3000rpm or just above? (atleast thats what it feels like!)
    HAHAHA
    Boronia VIC
    Quote Originally Posted by ryana89 View Post
    yep, 4-2-1 extractors. The torque comes in pretty early on a stock 2E makes the MK3s a pleasant thing to drive and allows the tall gearing.
    Dunno where my torque curve is, too many different cams. Current Cam is 306° and its still got torque enough from low rpm.
    7? MK1 Caddy
    12 Amarok
