Results 1 to 10 of 49
Thread: Can we talk MK1 brakes for a second?
    Aug 2009
    I'm needing rotors at a minimum for RWC.
    So I know there's a few direct bolt-up options for a MK1.
    What's the cheapest, easiest, most common upgrade for a car like mine, you guys?
    (or what are all the options, pros and cons of each I suppose)
    Right now, I'm not fussed about making my car stop fast or handle well. I just need to get it on the road.
    But I'll probably be looking to upgrade down the track sometime, so I'm happy to stretch the budget now to save doing it later.
    (by the way, i tried searching )
    Oct 2005
    Nowra, NSW
    Few options out there;
    You can get GTI rotors and calipers which go straight on, these also came on late model cabrio's. I am running these atm and are much better than standard.
    Another option is getting your new stock rotors and giving the entire braking system a once over, so check the booster, master cylinder and lines for leaks, check the rear drums for leaks and adjust them. I think you can get kits to replace all the seals in things in the master cylinder which even if you do upgrade would be a good idea. You can also check the bar that runs across the firewall for any play and adjust, not sure how much this helps though.
    You can put in a Seat booster setup which helps, couple of threads on here about it. Jarred and Pete Jones both have threads going over the process
    Mar 2009
    Empire Bay NSW
    sorry dont know how to create a link check out the Pete Jones do it yourself thread ........
    Jun 2006
    Orange NSW
    Depends on your budget..
    In you just want RWC, get everything sweet and give it all a service. If you want some better braking, get some GTI hardware. Straight bolt on (just need some proportioning valves and some different lines at the end) and you're set.
    That is of course, only MY opinion.
    Aug 2009
    Having to replace them mostly because the front discs have a 1.5mm lip all the way around!
    I'm a brake system n00b by the way haha.
    I've done pads before, not fluid or plumbing etc.
    I just need to do it for RWC. So I can basically just replace the rotors (& pads while I'm there) and be all set.
    Oakleigh VIC
    I've covered brakes system upgrades in these project threads.
    http://www.vwwatercooled.org.au/f55/...ect-24078.html
    http://www.vwwatercooled.org.au/f55/...ace-13857.html
    This is how you do a booster conversion.
    http://www.vwwatercooled.org.au/f20/...mk1-11689.html
    Here's some more stuff.
    http://www.vwwatercooled.org.au/f20/...tos-13700.html
    and yet more.
    http://www.vwwatercooled.org.au/f13/...its-11535.html
    Here's how you upgrade the rears.
    http://www.vwwatercooled.org.au/f20/...k-i-11719.html
    If you liked that you might also like
    http://www.vwwatercooled.org.au/f13/...ory-11723.html
    Or perhaps this.
    http://www.vwwatercooled.org.au/f13/...job-11595.html
    and that's just the stuff I wrote.
    I'd be surprised if you can read all of that and have any questions left.
    In reality MK1 brakes are pretty good. Look at the reviews from back in the day. If yours suck they probably just need fixing, they are 30 years old after all.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Aug 2009
    Torquay, victoria
    Mate I can help if u want, I just did mine not long ago. Got all my stuff from clutch and brake in little ryrie st. They can even just machine the discs u have in there already for like $20 each if I remember right. Seen as it's just for a rwc this would be the cheapest and easiest way.
    Aug 2009
    That sounds like a good option Mark. I'll get onto them once I've got another permit. :roll_eyes:
    Peter, thanks a lot for that!
    I wasn't aware you'd written up so much on it/everything. I did look, obviously not hard enough!
