yeah comparing it with spyda's picture the standard one does sit in further and a bit more snugly but as brenton said - its only thin malleable metal and could probably be made to fit or close enough...
Mk1 2dr ABF
Backyard butchery... the GTI I have here is an 80 with the small tail lamps originally, has been hacked for the larger later model lamps. Looks like it leaked a load and as Loon has already mentioned, doesnt sit correctly either.
If you dont wish to weld in the whole panel, you could possibly graft the section the lamp sit in to the existing body, however the rear panels are available, may as well do the job correctly for the most satisfaction..
Speak to Richard ..
http://www.golfmk1.co.uk/Items.php?c...group=VWPANELS
Good luck.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
shortcuts lead to long delays and taillights are pretty fragile..but anything can* be done.
ok. i think i might have to avoid it then. it's a fair bit of effort and money that will go into it when really it is just for the look...
Mk1 2dr ABF
Damn, I've already bought big tail lights thinking it would be a simple swap.
As I have no experience with bodywork, how much would it be to get a body shop to do a weld job like this (swap current 76' back panel for big tail light panel - not including paint)?
76' 2dr Kjet
hahahaha
i can't imagine it would cost that much...100-200?? max? if that?
Mk1 2dr ABF
Panel cost me about 160 quid when i bought it, (~ $360 ++) then there was shipping it down to my container guy in surrey, then the cost of getting it thru customs here. so for a new panel, around the $450 - 500 dollar mark before getting it anywhere near the car you want to weld it in to.
best option is to salvage the one loon has and fit it to your shell if your on a low budget.
Cheers,
Grant...
76' 2dr Kjet
