Results 1 to 10 of 20
Thread: can big taillight be done?
    Mar 2009
    hi all...
    just wondering if it is possible to make the euro style big taillight fit instead of the Australian, and where ever else it was done, small taillight?
    from what i have seen i think there would be a little bit of cutting involved to make the taillight slot larger but besides that i can't see anything else to stop you?
    has anyone done it? tips...
    tom.
    Mk1 2dr ABF
    Jun 2006
    Melbourne, Victoria
    Very easy to do. It is just a case of cutting the body to the correct shape. Make sure you apply anti rust on the edges where you cut and make sure you get the bulb holders with the tailights.
    Camden, Sydney
    Actually, the lines on the early car are not right and will make the light stick out too far at the edges and the bottom. You will end up grinding bits off the light cluster too and it will never sit 100% correct.
    I have a rear panel and taillights if you want to do it properly.
    Mar 2009
    how early will this be the case for? 1978?
    thanks.
    Mk1 2dr ABF
    Apr 2006
    Hobart,Tas
    I have seen a few done and I didnt like the fit. Plenty of sealer had been used .
    On my comp. Golf I replaced the rear panel with the later version. Was all good that way!
    Camden, Sydney
    Quote Originally Posted by dub1 View Post
    thanks.
    Yup, all panels up until the correct one. 1980/81
    Mar 2009
    ahk. by replacing the rear panel does this not involve breaking the weld or the original panel and re-welding the new panel? seems a lot more tedious that making the big tail lights fit nice...? maybe not, i haven't actually looked at how the rear panel comes out...
    Mk1 2dr ABF
    Camden, Sydney
    Yup, involves welding. Not that much but definately welding.
    You havent tried fitting the lights to the wrong panel either. I have and they dont fit well.
    Here was my attempt and I was never more than 80% happy with how they sat and I wasted days on em
    Mar 2009
    yeah not too bad actually. you would notice it as much if you didn't know it wasn't standard...does it leak water?
    Mk1 2dr ABF
    its only thin steel , i reckon with a bit of panel beating knowledge you could recreate the right shape to mount with only a bit of sealant. measure twice cut once.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
