Weird wiring Woes
Got a problem with my Indicators,
When i turn them on or switch hazards the light comes on dash, but no lights around car come on or blink.
I have even pulled the plug behind fusebox and used a test light on the correct pins to see if i get anything.... i get nothing, is there a way to check the wires are working from switch to fusebox? (ive also tried a different indicator stalk)
I have tried 2 different wiring looms, and 3 fuse boxs and 4 relays for the blinkers.
Any ideas? i must be missing something if every combo i tried fails :S
There is no engine in car atm, surely that would have no effect?
<space for rent>
My initial thought was that it might be a fuse, but since you've swapped fuse boxes around maybe not.
Do you have indicators, it could be the flasher units kaput or connected incorrectly.
i have nothing :S
Think the flasher unit sits above fuses in slot K? ive tried a few different units.... unless its somewhere else?
<space for rent>
Ha, dont worry, fixed it
Turns out the Flasher unit is a 3 pin relay, not 4. and it goes on the far right (for me anyway)
<space for rent>
- You may not post replies
- You may not edit your posts
Forum Rules
