Results 1 to 10 of 14
Thread: Bypass transmission fluid cooler?
    Jun 2008
    Would you do it do get you around in the short term ??
    Mine has spat all the coolant out and I believe it is damaged, the oil section is fine, but need to get home, bypassing it would seal up the coolant again, but not sure what damage I may cause?
    Any suggestions.
    1993 MK1 CAB ! Work in Progress........
    Sep 2005
    If a 1977 GLS auto box fits, ive got 1 in my shed!
    No idea on bypassing it tho.
    Jun 2008
    Quote Originally Posted by intensem1 View Post
    Mate I have bypassed it and the leak has stopped so tells me it is the automatic transmission fluid cooler.
    Has your still got the cooler on it mate ?
    It is about 12mm by 15mm, and has two hose outlets and is fixed onto the bellhousing by two bolts ?
    May 2006
    Maroubra NSW
    12mmx 15mm is a pretty small oil cooler!
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    Jun 2008
    Quote Originally Posted by smithy010 View Post
    sorry CM !
    Camden, Sydney
    Bypassing it will get you home.
    If you driveit like that too long, the transmission wont be cooling and could be damaged.
    Jun 2008
    Thanks matey, I have solution to get me home.
    Now All I need is for you to get me a new or second hand one sir
    Jun 2008
    How long is too long mate, roughly speaking, I driver her for an hour twice a day max.
    I am struggling to locate the part I need, but need to get to work in the mean-time, however do not want to create more damage...
    There was a thread on a auto to manual cabrio conversion not long ago. So i guess someone has a spare box around. A quick search will answer all.
    1991 Mk1 Diesel Cabriolet
    Sep 2005
    cooler must be gone as i cant see anything like it.
