Page 2 of 27 FirstFirst 123412 ... LastLast
Results 11 to 20 of 270
Thread: build thread :)
    May 2012
    Tullamarine
    Nice buy! Does it start/drive? And what's your intentions on this mk1?
    MK1, 1976 golfLS, 4 door (SOLD! Will be missed)
    MK1, 1980 golfGLD, 4 door (1.8l, 8v, 5 speed)
    Mar 2013
    Act
    Quote Originally Posted by 5teve View Post
    It did start and drive, but my brother had to drive it up from Melbourne and burnt out a valve, so engine rebuild is on the way
    Plans are too paint it, slam it on some coils, and stick some nice wheels etc on it hit some shows up and all that
    Can anybody enlighten me on the front panels? I've removed the bolts from the left panel, and the front is swinging but the back section won't budge. The right panel is also wierd, there's a really wierd device thingo blocking the top bolt that I need to get to, any advice?
    May 2012
    Tullamarine
    That's a shame!!
    Hope to see some picks as you progress
    About the front panels to start off I'd take the front wheels off which will make it easier to work and then look inside the back of the guard where it wont budge and you would see a few bolts (3 bolts from memory) they might be covered in sealant if I'm not wrong, which will be a challange to see!
    Give that ago!
    Mar 2013
    Act
    That's a shame!!
    Give that ago!
    I've removed all of the bolts and stuff, but the rear part of the panel still won't move, I think there's a lot of sealant keeping it there, and I've bent the panel already trying to get it out :l I've tried heating it up and all that, still won't budge
    Mar 2013
    Act
    Not much progress, however I've gotten that wierd spoiler thingo off, and I gave it a good clean, boot still won't open and I still can't get the panels off, fml
    Mar 2013
    Act
    so ive decided to revive this thread
    Quite a bit has happened to the car since i got it, fresh paint (done by me, first ever respray), me and my dad tried to recover the dash as seen below, and basically all of the major parts of the build. i also have no clue if the pictures will work
    build thread :)-img_3902[2]-jpg
    put in a new headdeck and added speaker holes in the front and back door cards for 4"fusion speakers. didnt turn out to badly
    build thread :)-img_3903[1]-jpg
    build thread :)-img_3904[1]-jpg
    go the steering rack reconditioned at capital steering & suspension
    build thread :)-img_3894[1]-jpg
    engine rebuilt, 3 grand later. stock standard 1.6 8v rebored to a 1.8, got high comp pistons put in and its running a 10:1 compression ratio, which isnt to bad to be fair.
    build thread :)-img_3905[1]-jpg
    What head gasket are you running?
    Back in the 80's we had heaps of problems with head gaskets on my mate's bored out 1.6 because of the reduced surface area around the cylinders.
    Mar 2013
    Act
    Just using the gasket that the head shop gave us, bit of gasket glue and i think it'll be be perfect. it looks like the gasket will fit the head perfectly when i was trial fitting it.
    Mar 2013
    Act
    exhaust manifold from racelandus came, $250 shipped so it was a bit of a bargain.
    build thread :)-img_3884[1]-jpg
    tried to redo the seats, used VHT vinyl die and they came up wonderfully! also with a new carpet
    build thread :)-img_3901[2]-jpg
    Bumpers are a mess, completely warped both front and back, does anyone know if they can get straightened out and by a shop in canberra?
    thought i'd show what im zipping around on until i get my P's in a month
    Hyosung gt250r
    build thread :)-img_3907[2]-jpg
    my brother just bought this 10 year old super bike, for how old it is its insane. does 200km/h to 300km/h in something 6 seconds. :O
    It's not 200 to 300 that impresses me, it's 300 to 0.
