Page 21 of 27 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 270
Thread: build thread :)
  1. #201
    Mar 2013
    Act
    hey guys, I need some help with figuring stuff out,
    1. the tacho doesn't work and I have no clue at why or how to fix it
    2. the car runs well ad then messes up when you tap the voltage regulator, as in charges at 16.4v instead of 14.7, it also runs really rough at the same time. is the voltage regulator messed up or what?
    But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
    I just reply, "your daughter, sir." - some dude on stanceworks
    I had fixed half the broken crap but that just meant it was still halfway inoperable
  2. #202
    Jan 2010
    Melb Westsideeeee
    For the rev techno, there is a blue wire at the back of the cluster, to test if it works, you can directly place it on the ...... +? Side of the coil. I can't remember, but it's either side of the coil.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  3. #203
    Voltage regulator sounds like it needs replacing. 14.7 is normal, 16v isn't and will do some damage to the electrical circuits.
    Got the wheels on yet?
  4. #204
    Mar 2013
    Act
    Quote Originally Posted by GeorgeMK1 View Post
    how would i go about connecting it to the coil? its not that long is it?
  5. #205
    Mar 2013
    Act
    repco wouldnt do regulators would they?
    the wheels are hopefully going on next thursday when i get paid enough for tires
  6. #206
    Mar 2013
    Act
    completely off topic but damn this is cool
    Operation Dirty Penny - '75 Merc 240D - Page 19 - StanceWorks
  7. #207
    Mar 2013
    Act
    fun fact, head gasket is blown
  8. #208
    Nov 2008
    Canberra
    Oh no! That sucks donkey ****s..
  9. #209
    Hope they now make head gaskets out of better material than they did 20 years ago. Back then I had a mate with a 1.6 bored to 1.8 which was always blowing head gaskets because of the reduced area between the cylinders. Bigger bores = less surface area pressing against the reinforced part of the gasket that seals in the bore/cylinder.
    If you can get a 1.8 headgasket to suit I’d highly recommend it.
    Paul
  10. #210
    Mar 2013
    Act
    Hello!
    Alas i am not dead and the golf is progressing be it so slowly..
    i finally managed to get the wheels that i bought off paul (sports racer) onto the golf, once i can get it off my phone onto the computer..
    i have run into some hurdles with the monstrosity, namely a faulty temperature gauge and a sheared speedo cable.. i've got the replacement for the speedo cable just needing to go in (tomorrow) but im wary about the temp sensor.. this is the second sensor i've had in the golf and its also bust, does getting it really hot mess with the way it performs? its the sensor from the radiator.
