Page 16 of 27 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 270
Thread: build thread :)
  1. #151
    could it be that?
    i know i had a similiar problem on a different car when the IAC valve went bonkers. would almost stall coming to a stop.
    might just need adjustment.
    84 MK1 GTI
    01 DC2R
  2. #152
    Mar 2013
    Act
    Quote Originally Posted by Big Yellow View Post
    could it be that?
    ill have a play with it, it does need a tune but..
    Car is currently off the road, need to find out where the oil leak is coming from and why the car is running 120 degrees...
    But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
    I just reply, "your daughter, sir." - some dude on stanceworks
    I had fixed half the broken crap but that just meant it was still halfway inoperable
  3. #153
    Mar 2013
    Act
    Ok them, question.
    What could be causing the constant highs of 110-125 degrees? the coolant is full and theres no leaks.
    Would having a fuse thats only half of whats meant to be there cause the fan to stop working? Because the fan was working with that fuse for a while.
    Cheers.
  4. #154
    Jan 2012
    St Albans, Victoria
    Quote Originally Posted by Pilks View Post
    Ok them, question.
    Cheers.
    No. Maybe cheek the fan if it's actually working by running a couple of wires to it and connect it directly to the battery. If it does work the switch might be faulty and you could have a sticking thermostat if it's really running hot?
    Might also pay to run a external temp gauge.
  5. #155
    You've modified the motor so it's now a 1.8. If you're running the original radiator it probably isn't good enough for the extra heat generated by the engine.
  6. #156
    Mar 2013
    Act
    Quote Originally Posted by Petska84 View Post
    what do you mean by external?
    the original radiator was messed up, i am running a new one however i dont know if its enough either, looks exactly the same size as the old one.
  7. #157
    Aug 2011
    brisbane
    have you re-jetted it?
    is it possible, that now it's a 1.8l,it maybe its running too lean, that can make them run hotter
  8. #158
    Mar 2013
    Act
    Quote Originally Posted by ericcs View Post
    I havent rejetted the carb, its still stock standard i just pulled it apart and gave it a clean.
    I found one reason for the temperatures. the thermo switch on the radiator was fried, so i ordered a new one off heritage ($31 for a switch is insane..)
  9. #159
    That should go a long way to fixing the problem but you really need to make sure the carby is jetted properly or it could lean out which will destroy your pistons.
    What colour is the inside of the end of the exhaust pipe? It should be a healthy grey - check other cars to see what shade of grey. If it's too light then it's running lean.
  10. #160
    Mar 2013
    Act
    how would i go about rejetting it?
    ill have a look at it now, if its running too lean do i screw the mixture screw in clockwise or out counterclockwise?
