Page 12 of 27 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 270
Thread: build thread :)
  1. #111
    The meeting at Goons has been postponed to tomorrow so I'll be just around the corner.
  2. #112
    Mar 2013
    Act
    okay then, so mum banned me from doing work on the car in the week because i havent been studying enough (fair call really) so i hope to have the carb back in the car tomorrow night, and thanks to paul and goon for the help on tuesday! was great meeting you guys aswell
    also, if anyone has experience with subarus. do 02-07 impreza struts fit into 00' foresters? because i know in american models they do (stanceworks tyvm)
    cheers
    Reid
    But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
    I just reply, "your daughter, sir." - some dude on stanceworks
    I had fixed half the broken crap but that just meant it was still halfway inoperable
  3. #113
    Good to meet you too. Hope you get the Golf running soon so you can start to enjoy living with a MK1.
  4. #114
    Mar 2013
    Act
    ok, so every single thing in the golf works..
    except reverse. i dont know a thing about how the linkage works and dad took a look and cant figure it out either, he tried to adjust it but its still not working
    this is what makes a good day bad.
  5. #115
    Should be an easy fix.
    Put it in neutral and move the gearknob left and right whilst someone watches the linkages. That way you can see which linkage needs adjusting. Now adjust it longer - does it get into reverse? No, then shorten it. With a bit of adjustment you should get it to work.
    And congrats on getting this far. Well done.
  6. #116
    Mar 2013
    Scarborough
    Just making sure, not assuming that you don't, but you're selecting reverse by pushing the gear shift down and then into first yeah? The procedure for adjusting linkages is written up fairly well in the bentley manual, I can scan it tomorrow if you don't figure it out from what you've got!
  7. #117
    Mar 2013
    Act
    yeah thats what im doing, that would be great if you could doesy thanks!
  8. #118
    Aug 2011
    Canberra
    After I changed my shaft bushings, I had issues with Reverse being where 1st should be, and no Fifth...
    I had to losen the clamp at the end of the long front to rear shaft, slide the linkage off of the splined shaft, and rotate it a couple of teeth...
    Might help yours too...
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  9. #119
    Mar 2013
    Act
    ill give it a go, that clamp is at the one like right next to the steering rack yeah? and what way did you rotate the linkage?
  10. #120
    Mar 2013
    Scarborough
    Looking at the front of the car rotate the shaft clockwise to make it easier to get to the 1-2 gate is where I would start. I'll scan the pages from Bentley at lunch time mate.
