Page 11 of 27 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 270
Thread: build thread :)
  1. #101
    This is going to need someone to diagnose. Where in Canberra are you - I can have a look after work some time if you want.
    Are you coming out to Goon's on Monday?
  2. #102
    Mar 2013
    Act
    just in wanniassa, getting some new leads and a dizzy cap so that should help it run smoother i hope, and maybe let it idle? it is running on 3 cylinders atm.
    and i wasnt aware anything was on sorry.
    But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
    I just reply, "your daughter, sir." - some dude on stanceworks
    I had fixed half the broken crap but that just meant it was still halfway inoperable
  3. #103
    Nov 2008
    Canberra
    Come along on Monday Pilks! We've got a few of us who are up for a little meet and greet at 6 PM in Kambah.
    Seems like the timing is off, have you got a timing light? Could be a number of things though, I am just stabbing in the dark!
  4. #104
    Mar 2013
    Act
    ill see if i can get! cheers for letting me know
    we've got it all timed, havent used a timing light, dont you need idle for a timing light? (please correct me if im wrong)
    pulled the carby of the manifold today and about to give it a good clean and try to set it to the specs its meant to be.. can anyone link me to a page telling me how to tune a solex 34 pict 5 carb? can only find ones for a pict 3. (they wouldnt happen to be the same would they?)
    cheers, reid
  5. #105
    Mar 2013
    Act
    so i took the carby out of the car, completely took it apart and cleaned EVERYTHING. im not sure how to set the fast idle screw however have got the bypass screw and air mixture screw sorted to factory specs.
    can someone please enlighten me on what this hook and spring looking thing does.
    build thread :)-img_4589[1]-jpg
    on another note, its funny how many cuts and bruises you find after a day of working on a car that you dont even know happened.
  6. #106
    Mar 2013
    Act
    okay then, update.
    put new bolts in the inlet manifold because there was a big gap between the gasket and head, about a mil wide so thats been taken care of.
    new problem which i think is the problem for it not idling. when we took the air cleaner off and looked at what the carby was doing when running we saw a problem. when taking your foot off the accelerator then a load of fuel shoots into the carby (between a teaspoon and table spoon full) and floods it, have absolutely no clue why.
    cheers guys
    reid
  7. #107
    You've got the manual fuel pump (the one inside the carby) setup backwards. It's supposed to pump the fuel as you accelerate not decelerate.
    Your linkage should look something like this so that as you push down on the pedal the long arm moves clockwise to open the throttle
    build thread :)-34pict-3-jpg
    You can see the idle adjustment screw on the end of the arm.
  8. #108
    Mar 2013
    Act
    how do i fix the setup of the carby? and in this picture
    it looks different to the one i have in the post above yours, it seems to not have the arm and spring that mine does?
    also i wont be able to make it tonight, schoolwork is getting the best of me, sorry!
    cheers
    Reid
  9. #109
    The basics are the same. The long piece that you are touching in your picture must move clockwise to control the throttle opening and work with the brass assembly above your finger. In your picture you have the long piece on the left of the brass bits, it should be on the right.
    I'll pm you my phone number. Give me a ring.
    Paul
  10. #110
    Mar 2013
    Act
    so i have to swap the arm over to the other side? the car stills runs and accelerates fine and that arm just sits there doing nothing.
    ill give you a ring tomorrow afternoon after school also
