Trying to get the mk1 back on the road, i recently replaced the brake boost and master cylinder with units off a Cordoba following Peter Jones tutorial.
The reason for the replacement was that the previous master cylinder failed, brakes barely worked, it was sucking in air, the rear drums would not bleed and I ended up finding break fluid in side the brake booster.
While I was at it I also threw on a set of 280mm disks and VR6 calipers.
I found time today to move the cars about and get the mk1 out on to flat ground to bleed the brakes. Starting with the rear right, after a while the air in the line had come out and brake fluid finally started to flow but very very slowly and still had bubbles. I wasn't making any progress so i thought I see how i went with the other brakes.
This is what ****s me.........the front right doesn't do anything, no bleeding, no air, nothing. The front left bleeds perfectly but no change in pedal feel. The rear left barely does anything either, some fluid comes through with a lot of air when i use the hand pump and the rear right is a bit better but still consistent bubbles that don't seem to want to go away.
The brake pedal is very soft, goes down quick with ease and comes up very very slowly.
Any ideas?
