Its hard to diagnose because you've changed nealry all the parts and only with second hand bits.
Heres a list of reasons that I have expereinced which made bleeding nearly impossible or impossible:
> failed seals in MC
> cracked hardlines
> leaking threaded joints
> rusted through hard lines
> cracked/persihed rubber lines
> failed seals in rear drum pistons
> failed seals in caliper pistons
From you description about the rear drums not bleeding, I might suspect that you have a problem with the lines running to the back.
Hope that helps.
