When I had this issue I had to change the slave master cylinder at the back it was spitting oil everywhere![]()
quick one guys.
The warning light on my dash is on. It's the brake warning light above the handbrake light.
how do i get this to go off, or rather what causes this to go on???
Dom's suggested air in the lines, so i'll re bleed them later is afternoon with stu's help, although he doesn't know that yet.
any ideas guys??
thanks.
i don't think it be that steve, would have been picked up by the guys at the roadworthy test.
They come on occasionaly.
To get them off, disconnect the battery leads for 10-20 seconds
Andrew
My next suggestion would be what Dom said air in the lines?
Occasionally during my gravel rally days years ago, after giving my Golfs a hard time the light would come on. This was usually after a bit of brake fade or whatever and must be due to a difference of pressure in the 2 circuits in the master cylinder.
There is a diode at the back of the light which needs to be de-energised by removing the battery teminals. If it happens again then thoroughly bleed the brakes again, do the battery terminal thing again and all should be fine.
Easy!!
Thanks Andrew!! legend, now my car is roadworthy! As a precaution I might still bleed the brakes soon.
Thanks Jarred, and because of getting some feedback I am only too happy to answer further queries of yours!!
It helps all if the cure is verified.
