Wonderful photos - looks awesome!
So, did the standard wheels fit over those bad boy calipers?
well I finally bit the bullet and (with santa's help) i got serious with the golf's brakes.
Went from this
to this awesome goodness
6 pot billet aluminium race brakes
so much lighter than the previous brakes and should stop ALOT quicker now. The previous units were great and i couldn't fault them for sport and sprint driving but i want to step it up further for sustained track attacks.
more to come
77 Golf tarmac rally
89 porsche 911
80 Rabbit 4dr
11 mk1 and 2\'s in various states of undress
KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
well the 15" fit...............just, has about 3mm clearance but it does fit. I am changing the wheels later on for a different set of rims as I have 12 of these rims some will have to go.
89 porsche 911
80 Rabbit 4dr
What size are the disks??
280 or something more magical![]()
Was it this?
And were the old caliper mounts bolt on as well or did you have to modify/replace the hubs?
Resident grumpy old fart
Looks good man, I was tempted to grab some of those from eBay as well.
Any reason your rotors are now facing a different direction to what the previous ones were? I just noticed that the slots were facing the opposite way to the ones you had on originally.
Driver Motorsport Tuned | Melbourne Car Meets | Insta: @VLNTVADERR
yeah that is close to what these are and they a great made bit of gear hey and I purchased dealer direct after a lengthy discussion. The discs are 286mm as i still want to retain the mk1's quick acceleration and revvy nature so the smaller the rim the better hence my keeping a 15" setup. Disc direction is purely manufacturer instructions. Black diamond recommend 1 direction, K sport (AP) recommend this direction. Just need to change around the bleeders and it is ready for the road.
89 porsche 911
80 Rabbit 4dr
In the seventh photo, is that a crack in the wheel or just a misadventure with the pencil in MS Paint?
Wow - that's observant - looks like a crack in two spokes
