Results 1 to 10 of 12
Thread: brake upgrade for the race car
    Feb 2006
    Perth Western Australia
    well I finally bit the bullet and (with santa's help) i got serious with the golf's brakes.
    Went from this
    to this awesome goodness
    6 pot billet aluminium race brakes
    so much lighter than the previous brakes and should stop ALOT quicker now. The previous units were great and i couldn't fault them for sport and sprint driving but i want to step it up further for sustained track attacks.
    more to come
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Dec 2012
    Sutherland Shire, Sydney
    Wonderful photos - looks awesome!
    So, did the standard wheels fit over those bad boy calipers?
    Feb 2006
    well the 15" fit...............just, has about 3mm clearance but it does fit. I am changing the wheels later on for a different set of rims as I have 12 of these rims some will have to go.
    89 porsche 911
    80 Rabbit 4dr
    Dec 2008
    Bentleigh, Melbourne
    What size are the disks??
    280 or something more magical
    Oct 2010
    Melbourne, VIC
    Was it this?
    And were the old caliper mounts bolt on as well or did you have to modify/replace the hubs?
    Resident grumpy old fart
    Looks good man, I was tempted to grab some of those from eBay as well.
    Any reason your rotors are now facing a different direction to what the previous ones were? I just noticed that the slots were facing the opposite way to the ones you had on originally.
    Feb 2006
    yeah that is close to what these are and they a great made bit of gear hey and I purchased dealer direct after a lengthy discussion. The discs are 286mm as i still want to retain the mk1's quick acceleration and revvy nature so the smaller the rim the better hence my keeping a 15" setup. Disc direction is purely manufacturer instructions. Black diamond recommend 1 direction, K sport (AP) recommend this direction. Just need to change around the bleeders and it is ready for the road.
    89 porsche 911
    80 Rabbit 4dr
    Jan 2009
    In the seventh photo, is that a crack in the wheel or just a misadventure with the pencil in MS Paint?
    Dec 2012
    Wow - that's observant - looks like a crack in two spokes
    Quote Originally Posted by Martin View Post
    It's something on the lens. Otherwise it's across the spokes and inside them. Look closely.
