The brake upgrade options for your mk1 golf
ok Guys, after much research and actually doing this I have assembled together a heap of the basic (and cost effective) brake upgrade options for the mk1 golf. I have used all of these whilst in competition and each upgrade was done as the next step. The first thing i would recommend for most before playing with discs and calipers is invest in a mk3 booster and do the "Peter Jones" mod whilst you are at it install a 22mm master cylinder to make the most of any future caliper upgrades. Subsequently I have again upgraded my rally car so will be offering all this gear up for sale in the new year. Everything will be complete (minus brake hoses) with freshly rebuilt calipers, carriers, new discs (some have very minus surface rust as they have been on the shelf for years but will disappear on the first stop), new pads, adaptors and all bolts. Pm me if you are interested in any of them.
For comparison
The std mk1 GL, GLS and diesel brakes. 239mm non vented single piston calipers
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/stdmk1brakes1_zpsc13fba3b-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/stdmk1brakes2_zps5f04ae76-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/stdmk1brakes15_zpsbf7a7c4d-1.jpg)
The Mk1 GTi brake setup, slightly bigger caliper with 239mm vented discs. The kit is up for sale and has pagid fast road racing pads installed, 2100km old only and heaps of life left. These pads do not fade no matter what you do to them. No adaptors needed as it bolts straight up to the mk1 hub and will clear 13" rims
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/mk1gtibrakes1_zpsfd488874-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/mk1gtibrakes2_zps53f1adfb-1.jpg)
The next option moving forward is a 256mm vented disc and 54 series caliper. Big Improvement to braking over the 239 mk1 GTi setup. No pics sorry as still boxed but comes with new discs, rebuilt calipers, resleeved carriers and adaptors to bolt straight to mk1 hub. 30 minute job to do both sides. Will require minimum 14" rims
Option 3 is a step forward again and is the 280mm big disc upgrade. This uses a mk1 gti caliper matched to a 280mm custom offset disc and is a step again over the 256mm option. This kit comes with newish Black Diamond combination discs (1200km old) and has no warping or grooves what so ever, they present as new, also caliper adaptors and hardware. Just needs mk1 GTI calipers or I can supply at extra cost. Kit requires a minimum of 15" rims (also for sale very very soon)
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/TSRbigbrakekit_zps08c93d26-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2012/12/TSRbigbrakekit2_zpsd0d50f14-1.jpg)
77 Golf tarmac rally
89 porsche 911
80 Rabbit 4dr
11 mk1 and 2\'s in various states of undress
KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
