Results 1 to 3 of 3
Thread: brake problems
    PERTH
    brake problems
    hey i am at the stage of putting brake fluid in my system after a newish master cylinder, but when i push the pedal it makes a whosshing noise and doesnt seem to be pumping the fluid through enough for me to bleed the brakes as it trickles out like your wang after a 2 night bender on the turps........ does the engine have to be running to provide the vacume to the booster or does this sound like an air leak, the noise is coming from the booster and havnt experienced it befor and cant find the prob, maybe im over looking something simple.... pls help as my car is useless with out brakes,,,,,,,,
    eeeeeeeeppppp.........
    the golf is not dead.
    Camden, Sydney
    Bad booster or air leak I think.
    May 2006
    Maryborough Vic
    Talking
    should pump up even if booster is bad?
    check to see if everything is tight
    make sure its not sucking air from
    somewhere. if lines were dry can
    take a while to get some pedel
    try letting fluid just drip out of all four
    for five or ten mins keeping res full
    and try again, rag up cause messy
Similar Threads
  1. Electrical problems with VW Golf V towbar
    By JandG in forum Mk5 Golf & Jetta
    Last Post: 08-03-2009, 08:50 PM
  2. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  3. Brake problem for Safety check
    By TYPE 17 in forum Mk1 Golf
    Last Post: 02-12-2006, 07:26 PM
  4. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
