hey mate,
its definately the switch, and a common problem at that. i would suggest getting hold of a manula with wiring diagrams and use the colour codes to figure which switch is which. however, replace both, as its not much money to do so.
i have seen setups with 3 connectors and setups with 2 connectos, and i am only familiar with the 2 connector setup - however you will be able to find out what you need simply by using a jumper wire to short both connectors one at a time and see which one turns the brake lights on
HTH!
PS - ring HSY autoparts for those sensors, thats where i got them last time. in sydney, 8339 8339
