Should be two sensors off the master cylinder under the hood.
If not, it will be at the pedal![]()
Hi all
I have a 92 Citi Golf imported from South Africa. We have found that the majority of parts are that of a Cabriolet.
Having a bit of trouble with the rear brake lights, which we believe may be the switch.
Can anybody give me a heads up where this is located? I was thinking at the pedal, but an auto electrician suggested its at the master cylinder.
cheers
<space for rent>
correct, it is a sensor/switch in the master cylinder. A good OEM will do the trick.
1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
cheers guys, picked a new switch up and installed...very easy
