Results 1 to 4 of 4
Thread: Brake Light Switch
    Oct 2006
    Brake Light Switch
    Hi all
    I have a 92 Citi Golf imported from South Africa. We have found that the majority of parts are that of a Cabriolet.
    Having a bit of trouble with the rear brake lights, which we believe may be the switch.
    Can anybody give me a heads up where this is located? I was thinking at the pedal, but an auto electrician suggested its at the master cylinder.
    cheers
    Sep 2009
    Chillaxing in Tas
    Should be two sensors off the master cylinder under the hood.
    If not, it will be at the pedal
    <space for rent>
    Dec 2007
    Somewhere in Melbourne, Victoria
    correct, it is a sensor/switch in the master cylinder. A good OEM will do the trick.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Oct 2006
    cheers guys, picked a new switch up and installed...very easy
